ph_getcoltype PowerHome formula function
Returns the data type of the specified column number in the specified data retrieval area.
ph_getcoltype ( n, n )
n
The number of the data retrieval area (1 – 10)
n
The number of the column you wish to get the data type of.
String. Returns the data type of the specified column the last SQL Select retrieved from the specified data retrieval area as a string.
