ph_getdata PowerHome formula function
Gets data from a data retrieval area that was selected from an SQL Select.
ph_getdata ( n, row, col )
n
The number of the data retrieval area (1 – 20)
row
A long identifying the row you wish to retrieve from.
col
A long identifying the column number you wish to retrieve from.
String. The data stored within data
retrieval area n at row, col.
