ph_getdevicestat PowerHome formula function
This function retrieves an internally stored
device status for the specified device. It does not cause PowerHome to query the
device for its current
status.
ph_getdevicestat ( type, id, data,
flags)
| type |
Integer. The device type whose status you're trying to
retrieve. See Usage below. |
| id |
String. The ID of the device you're
retrieving the status of. |
| data |
Integer. The specific piece of data you'd
like to retrieve. See Usage below. |
flags
Integer. This parm is currently unused
and is reserved for future enhancements. Use a 0 until this parm is
implemented.
Return Info
Use this function to retrieve values
concerning a device that is internally tracked by PowerHome.
The type argument must be a number from 0 to 6.
The meaning if each is detailed below:
| 0 |
X10 |
| 1 | Digital
Input/Output |
| 2 |
Analog |
| 3 |
Insteon |
| 4 |
Insteon group |
| 5 |
UPB |
| 6 |
UPB link |
The data argument is a string that
must be chosen from the list below:
| 0 |
Returns the stat_msg column which is
the status message for the device as displayed on
the Device Status screen |
| 1 |
Returns the value1 from the view.
This will typically be the status of the device with 0 = unknown, 1 = off,
2 = on (in
the case of X10). |
| 2 |
Returns the value2. This will typically
be the level for a device |
| 3 |
Returns the value3. This will be string
representation of value1 (status) of the device |
| 4 |
Returns the lastchange column which is the datetime for when the status
was last updated by PowerHome |
| 5 |
Returns the stat_textcolor column. This
is the numeric color value for the
text of the status (this will match what is displayed on the Device Status
screen) |
| 6 |
Returns the stat_backcolor column. This
is the numeric background color
value for the status field |
7
Returns the stat_graphic column.
This
is the path and filename for the
status graphic that is being
displayed..
ph_getdevicestat(3,"KITCHEN",0,0)
This
example will return the status message for KITCHEN which is an Insteon
device. The value returned during testing was
"On"
