ph_getdeviceval PowerHome formula function
Returns data associated with specific
columns for a particular
device.
ph_getdeviceval ( type, id,
parm)
| type |
Integer. A numeric value equating to the type of device
whose values are being retrieved. See usage below. |
| id |
String. The ID for the device you're retrieving. |
parm
String. The particular parameter you're
retrieving the value of. See
usage below.
Double. Returns the numeric value from the
column specified in the parm parameter. - 1.0 is returned for invalid types.
-2.0 is returned if there is an error retrieving the data from the database.
-3.0 is returned if the parm parameter is invalid. -4.0 is returned if
the type parameter is one that is
currently
reserved (0,2,4,6,21)
Use this function to retrieve specific
values for a device directly from the PowerHome database without having to write
SQL statements.
The type parameter specifies the device type and is a numeric
value as defined below:
| 0 |
Reserved for X10 device types. Not yet
implemented. |
| 2 |
Reserved for Digital Input/Output types. Not yet
implemented. |
| 4 |
Reserved for Analog device types. Not yet
implemented. |
| 5 |
Insteon device type |
| 6 |
Reserved for Insteon Groups. Not yet
implemented. |
| 20 |
UPB device type |
21
Reserved for UPB links. Not
yet implemented.
The parm parameter is a string
representing the database column you'd like returned.
Below are the allowed
values for Insteon (type 5) device
types:
commcnt
ackcnt
nakcnt
timeoutcnt
ttacnt
xcommcnt
xackcnt
xnakcnt
xtimeoutcnt
xttacnt
failedmatch
xfailedmatch
iengine
usexaldb
firmware
activeflag
Below
are the allowed values for UPB (type 20) device
types:
commcnt
ackcnt
nakcnt
avgss
firmware
ph_getdeviceval(5,"KITCHEN","commcnt")
The above example
will return the total commcnt for Insteon device
KITCHEN.
