ph_getglobal_d PowerHome formula function
Retrieves a global variable and returns the data as a date.
ph_getglobal_d ( id )
id |
String identifying the global variable you wish to retrieve. NOTE: Should be all uppercase. |
Date. The data stored within the global variable will be returned as a date. You should only use this function if you know that the data stored within the global variable can be properly converted to a date.
• ph_getglobal_d("LAST_MOTION")
• ph_getglobal_d("[TEMP4]") --> where TEMP4 contains a Global variable name.
