ph_getglobal_t PowerHome formula function
Retrieves a global variable and returns the data as a time.
ph_getglobal_t ( id )
id |
String identifying the global variable you wish to retrieve. NOTE: Should be all uppercase. |
Time. The data stored within the global variable will be returned as a time. You should only use this function if you know that the data stored within the global variable can be properly converted to a time.
• ph_getglobal_t("LAST_MOTION_TIME")
