ph_getinsteonstat PowerHome formula function
Retrieves the current status of the specifed Insteon Device ID.
ph_getinsteonstat ( id )
id
String. The Insteon Device ID from which you wish to retrieve the status.
Integer. Returns the status associated with
the specified Insteon Device ID that PowerHome currently has stored. Valid
values are 0 for Unknown, 1 for Off, and 2 for On. If the ID does not exist,
then -1 is returned.
