ph_getmd5hash PowerHome formula function
Calculates
the MD5 hash value for the data specified
by the as_input
parameter
ph_getmd5hash ( as_input )
ph_getmd5hash ( as_input, ai_type )
| Argument | Description |
| as_input | String. The data to have the MD5 hash
calcuated for. Depending upon the ai_type parameter, this value can be
either a direct string, a hex encoded string, or a full path and filename
of a file to hash |
| ai_type | Integer (Optional). Determines how to
interpret the data supplied in the as_input parameter. Valid values are 0, 1, 2, and 3.
See Usage below for details. If this parameter is not supplied, a value of
0 will be assumed |
String. Returns the calculated MD5 hash value for the
specified data
Use this function to calculate an MD5 hash
for strings or files. The hash is done using the standard routines
available in C#. The ai_type parameter specifies how to interpret the data in
the as_input parameter. An ai_type value of 0 will interpret the data in
as_input as a string of ASCII bytes. An ai_type value of 1 will
interpret the data as a string of UTF8 bytes. An ai_type value
of 2 expects the data in as_input to be a hex encoded string (such as
the output of the s2h( ) function). The function will first decode the hex
string to their actual byte values and then perform the hash on the byte array.
An ai_type value of 3 expects as_input to contain a full path
and filename that you wish
to hash.
ph_getmd5hash("Test") - This example will return the following string: 0CBC6611F5540BD0809A388DC95A615B
