ph_getothercounter PowerHome formula function (Deprecated)
This function returns the value associated
with a counter object within a
controller
ph_getothercounter ( ctlr, counter
| ctlr |
String. The ID of the controller whose counter you want to
retrieve. |
counter
Integer. The number of the counter
within the specified controller that you wish
to retrieve.
Long. Returns the requested counter value
from
the controller.
This function is currently only supported
by the Elk M1 Gold controller. Counter numbers can be from 1 to 64.
This function will cause the controller to retrieve the actual value from the
controller vs retrieving a value from
PowerHome memory.
ph_getothercounter("ELK",5)
