ph_getothertimer PowerHome formula function (Deprecated)
Retrieves an internal timer value from a controller.
ph_getothertimer ( controller, timer )
controller
The ID of the controller.
timer
The number of the timer whose value you wish to retrieve.
Long. Returns the value of the timer you requested. –1 is returned if the controller is not available, -2 is returned if the controller does not support timers, -3 is returned if the timer is out of range.
Currently only supported by the CPU-XA/Ocelot controller. To use this function with the CPU-XA/Ocelot, specify the ID of the controller whose type is CPU-XA/Ocelot. The "timer" must be a number from 0 to 63 corresponding to the internal timer of the CPU-XA/Ocelot you wish to retrieve. Values will be in the range of 0 to 65535 for the CPU-XA/Ocelot.
