ph_getothervar PowerHome formula function (Deprecated)
Retrieves an internal variable value from a controller.
ph_getothervar ( controller, var )
controller
The ID of the controller.
var
The number of the internal variable whose value you wish to retrieve.
Long. Returns the value of the internal variable you requested. –1 is returned if the controller is not available, -2 is returned if the controller does not support internal variables, -3 is returned if the variable is out of range.
Currently only supported by the CPU-XA/Ocelot controller. To use this function with the CPU-XA/Ocelot, specify the ID of the controller whose type is CPU-XA/Ocelot. The "var" must be a number from 0 to 127 corresponding to the internal variable of the CPU-XA/Ocelot you wish to retrieve. Values will be in the range of 0 to 65535 for the CPU-XA/Ocelot.
