ph_getphwebdir PowerHome formula function
Returns the full path to the PowerHome webserver directory.
ph_getphwebdir ( )
String. Returns the full path to the PowerHome webserver directory.
This function returns the full path to the PowerHome webserver root directory. This location is contained within the pwrhome.ini file and can be configured from the PowerHome Explorer under Setup->Web. The default is: c:\program files\powerhome\web
