ph_getsqlrows PowerHome formula function
Returns the current number of rows in the specified data retrieval area.
ph_getsqlrows ( ai_id )
ph_getsqlrows ( ai_id, ai_type )
ai_id
Integer. The data retrieval area you wish to get the number of rows (1 – 20).
ai_type
Integer (Optional). The type of row counts
you would like returned for the Data Retrieval area. If this parameter is omitted, 0 will be used. See Usage below for details
Long. Returns the number of rows currently
within the data retrieval area for the specified ai_type value. Returns -1
if parameter ai_id is out of range. Returns -2 if
the specified Data Retrieval area is not valid. Returns -3 if parameter ai_type is out of range
Use this function to retrieve the
number of rows associated with a specific area within a Data
Retrieval Area.
The valid values for the ai_type parameter are:
0 - Return the count of rows in the primary section of the Data Retrieval area. This is equivalent to the system variables SQLROWS1 thru SQLROWS20
1 - Return the count of rows that have been filtered in the Data Retrieval area
2 - Return the count of rows that have been modified in the Data Retrieval area
3 - Return the count of rows that have been deleted in the Data Retrieval area
Any other value will return -3
• ph_getsqlrows(5) - Returns the
number of rows in the primary data section of Data Retrieval area 5. This is the
same value as system var
SQLROWS5
