ph_getsyspwrstat PowerHome formula function
This function retrieves power related status
from the Windows
system.
ph_getsyspwrstat ( parm
parm
String. The specific power parameter
you're requesting information on. See Usage info for
valid values.
Long. Returns the requested
parameter status.
This function will return values associated
with power from the Windows OS. If a UPS is connected (serial or USB) to
the PowerHome PC for monitoring, PowerHome can query and retrieve the various
status values.
Below are the valid values for the
parm parameter.
| aclinestat |
Returns the status of the AC
power. Returns 1 if AC is up, 0 if the UPS is running on
battery. |
| batteryflag |
Returns the status of the battery. 1 is
returned if the battery level is at least 66%. 2 is returned if the
battery is less than 33%. 4 is returned if the battery level is less than
5%. 8 is returned if the battery is charging. 128 is returned if there is
no battery. 255 is returned if the battery is not able to be read. |
| batterylifepct |
Returns the remaining level of battery
as a percentage. This would be 100 at fully charged and 0 at fully
discharged. |
| batterylifetime |
Returns the number of seconds of
battery life remaining. |
batteryfulllifetime
Returns the
number of seconds of battery life when at
full charge.
ph_getsyspwrstat("batterylifepct")
The
above example will return the a number from 0 to 100 (255 if unknown)
representing the battery
percentage.
