ph_getsysvol PowerHome formula function
Returns the current system volume level.
ph_getsysvol ( )
Long. Returns the volume level that the system is currently set to. This value will be between the min and max volume levels as returned by the ph_getsysvolmin and ph_getsysvolmax functions respectively. If a negative value is returned, then an error occurred.
