ph_gettimeout PowerHome formula function
Retrieves the value stored within the system variable TIMEOUT
ph_gettimeout ( )
Argument Description
Integer. The data stored within the system variable TIMEOUT will be returned as an integer. This variable represents the amount of seconds that a Message Box or Input Box macro command will wait before timing out. A value of 0 means no timeout.
