ph_geturl1 PowerHome formula function
Gets the resulting HTML code from the
specified
URL.
ph_geturl1 ( as_url, ai_type, al_timeout )
ph_geturl1 ( as_url, as_headers, ai_type, al_timeout )
| as_url |
String. The URL whose HTML you wish to retrieve |
| as_headers |
String (Optional). Additional HTTP headers you
would like to be sent as part of the request. Specify headers in the same
format that would be used for structuring a valid HTTP request. Separate
multiple headers with either a carriage return / linefeed pair or a
linefeed (use the same separator for ALL the headers). An example header may look like: "Accept-Type: text/html~r~nPragma: no-cache". If this parameter is omitted, an empty string "" will be used |
| ai_type |
Integer. A number representing the method of HTML retrieval
from the URL. See usage below for an explanation of the valid types |
al_timeout
Long. The max length of time in either seconds
or milliseconds (dependent upon the ai_type value) to wait for the HTML return before the function times out
String. The raw HTML returned from the
requested URL. Various errors may be encountered depending upon the method
used to retrieve the HTML specified by the ai_type parameter. If an
error occurs, the return value will start with "*ERROR* - " followed by a description of the error
This function is an upgraded and expanded
version of the original ph_geturl function.
The following table details the valid
values for the ai_type parameter:
| 0 |
A type of 0 will cause the HTML to be retrieved via a raw socket (this is the same as
the ph_geturl function). The HTTP request is constructed internally and then sent
via a raw socket. The al_timeout parameter is in seconds |
| 1 |
A type of 1 will retrieve the HTML using a Catalyst HTTP control. The al_timeout parameter is
in seconds |
| 2 |
A type of 2 will also retrieve the HTML using a Catalyst HTTP control but does so using
slightly different methods than type 1 in case one or the other has
compatibility problems. The al_timeout parameter is in seconds |
| 3 |
A type of 3 will also retrieve the HTML using a Catalyst
HTTP control but does so using a different method than type 1 or
type 2. The al_timeout parameter is in seconds |
| 4 |
Retrieves the HTML using an
PowerBuilder internal HTTP control. This method does not support
additional
HTTP headers and any specified headers will
be ignored. The al_timeout parameter is in seconds |
| 5 |
"msxml2.xmlhttp" control. The al_timeout parameter is in milliseconds |
| 6 |
"msxml2.serverxmlhttp" control. The al_timeout parameter is in milliseconds |
| 7 |
"winhttp.winhttprequest" control. The al_timeout parameter is in milliseconds |
| 8 |
Retrieves the HTML using a C#
WebRequest object. The al_timeout parameter is in milliseconds |
| 9 |
HttpWebRequest object. The al_timeout parameter is in milliseconds |
| 10 |
WebClient object with the DownloadString function. The al_timeout parameter is not relevant since
this method does not allow specifying a timeout |
| 11 |
WebClient object with the OpenRead function. The al_timeout parameter is not relevant since
| 12 |
Retrieves the HTML using a C# WebClient object with
the DownloadString function. The C# WebClient object has been extended such that it supports
timeout values. The al_timeout parameter is in milliseconds |
| 13 |
the OpenRead function. The C# WebClient object has been extended such that it supports
Any other value
Any other value will result in
an empty string "" being returned
ph_geturl1("https://weather.com/weather/today/l/28.69,-81.53?par=google&temp=f",1,5)
The
above example will retrieve the raw HTML for the weather.com website
using an HTTP Catalyst control. The function will timeout in 5 seconds if
the result hasnt been returned by
then.
