ph_geturlviaproxy1 PowerHome formula function
Gets the resulting HTML code from a URL using
the specified proxy server values.
ph_geturlviaproxy ( as_url, as_proxy, al_proxyport, as_authorization, ai_type, ai_timeout)
ph_geturlviaproxy ( as_url, as_headers, as_proxy, al_proxyport, as_authorization, ai_type, ai_timeout)
| as_url |
String. The URL whose HTML you wish to retrieve. |
| as_headers |
String (Optional). Additional HTTP headers you would like to be sent as part of the request. Specify headers in the same format that would be used for structuring a valid HTTP request. Separate multiple headers with either a carriage return / linefeed pair or a linefeed (use the same separator for ALL the headers). An example header may look like: "Accept-Type: text/html~r~nPragma: no-cache". If this parameter is omitted, an empty string "" will be used |
| as_proxy |
String. The proxy server the request will made through. |
| al_proxyport |
Long. The proxy server port |
| as_authorization |
String. The userid and password for the proxy server. Separate the userid from the password using a colon character. Example: userid:password. |
| ai_type |
Integer. A number representing the method of HTML retrieval from the URL. See usage below for an explanation of the valid types. |
| ai_timeout |
Integer. The max length of time in seconds to wait for the HTML before the function times out.
String. The raw HTML returned from the
requested URL.
This function is an upgraded and expanded
version of the original ph_geturlviaproxy function.
The following table
details the valid values for the type parameter:
| 0 |
A type of 0 will cause the HTML to be
retrieved via a raw socket (this is the same as the ph_geturlviaproxy
function). The HTTP request is constructed internally and then sent
via a raw socket. |
| 1 |
A type of 1 will retrieve the HTML
using a Catalyst HTTP control. |
| 2 |
A type of 2 will also retrieve the HTML
using a Catalyst HTTP control but does so using slightly different methods
than type 1 in case one or the other has compatibility problems. |
| Any other value |
Any other value will cause the function
to retrieve HTML using a Catalyst HTTP control using yet another method
different from type 1 or type 2. Each of the types have various levels of
compatibility and each type should be attempted to retrieve the most
satisfactory results for a particular website. |
The following examples demonstrate typical syntax/usage
for this function.
ph_geturlviaproxy1("https://weather.com/weather/today/l/28.69,-81.53?par=google&temp=f","192.168.0.150",80,"userid:password",1,5)
The above example will retrieve the raw HTML for the weather.com website using an HTTP Catalyst control. The function will timeout in 5 seconds if the result hasnt been returned by then.
