ph_getvarsub PowerHome formula function
Returns the value of the variable substitution parameter.
ph_getvarsub ( )
Argument Description
Integer. The value of the variable substitution parameter. If variable substitution is enabled, then 1 is returned.  If variable substitution is disabled then 0 is returned.
Within the pwrhome.ini file under the [Script] section is a parameter named VARSUBSTITUTION. If this parameter is set to NO, then variable substitution is disabled and syntax such as [LOCAL1] or {TEMP} within formulas will NOT be substituted and will instead be interpreted as literal text.  If the parameter is set to YES, then variable substitution will be performed.
ph_getvarsub()
