| Argument | Description |
| ai_type | Integer (Optional). A numeric value representing what type of the version you wish returned. If this parameter is omitted then a value of 0 is assumed. See Usage below for other allowed values |
The optional ai_type parameter determines the components that are returned that make up the version number. A value of 0 will return the main PowerHome version number. A value of 1 will return the sub version information. A value of 2 will return the combined version and sub version values together (this is what would be displayed in the Help->About window). Any other value will be treated as a 0. It should be noted that the sub version value may be blank in some versions of PowerHome
