ph_getwebbase64auth PowerHome formula function
Returns the base64 encoding of a userid / password used to access a webpage.
ph_getwebbase64auth ( )
String. Returns the actual base64 representation of the userid / password that was used to access the webpage. Use this function when you are validating userid / password combinations other than the master and guest accounts.
