ph_getwindowsdir PowerHome formula function
Returns the full path to the PowerHome machines windows or system32 directory
ph_getwindowsdir ( type )
type
An integer representing the particular Windows directory path to return. Use 0 for the Windows directory, any other value for the Windows System32 directory.
String. The path to the windows or system32 directory.
The returned values are the same as the system variables [WINDIR] and [SYS32DIR]
