| Argument | Description |
| as_ctlr | String. The ID of the Z-Wave controller |
| as_id | String. The fully qualified JSON name for the requested value |
| ai_type | Integer. The type of data you wish to have returned. Valid values are 0 thru 4 |
PowerHome maintains a JSON structure that contains the full device and status tree that is available within the specified Z-Wave controller. This is a flattened JSON structure of name/value pairs and is accessed by a fully qualified JSON name. In the case of a Razberry controller, this would typically look like this:
devices.20.instances.0.commandClasses.114.data.serialNumber
To retrieve the value for the fully qualified JSON name above, you would need to set the as_id parameter to "devices.20.instances.0.commandClasses.114.data.serialNumber". The specified Node ID and Command Class do NOT have to be defined within PowerHome.
The ai_type parameter must have a value from 0 to 4. A value of 0 will return the string value associated with the JSON name. A value of 1 will return the data type of the string value. A value of 2 will return the Invalidate Time for the JSON name. A value of 3 will return the Update Time for the JSON name. A value of 4 will return the Other value associated with the JSON name.
In normal usage, this function and the ph_getzwavedata( ) function will probably never be called. These functions are for those who want to access the Z-Wave data within PowerHome at its lowest level
