ph_insteonclearfailed PowerHome formula function
Zeroes the "Failed Match" column of a specific Insteon device or all Insteon devices.
ph_insteonclearfailed ( id )
id
String. The ID of the Insteon device whose failed match column will be set to 0. Use empty string ("") to reset ALL Insteon devices.
Integer. Returns a 0.
