ph_insteonrawbcast PowerHome formula function
Allows for the transmission of Insteon Broadcast messages (different from Group Broadcast messages).
ph_insteonrawbcast ( ctlr, address, cmd1, cmd2 )
ctlr
String. The ID of the Insteon Controller that will send the broadcast message.
address
String. A properly formatted Insteon address string consisting of 3 pairs of hex digits separated by periods.
cmd1
Integer. The CMD1 value to send. An integer from 0 to 255.
cmd2
Integer. The CMD2 value to send. An integer from 0 to 255.
Integer. Returns a 0 if successful. -1 is returned if the controller is not available, -2 is returned if the controller does not support Insteon.
Use this funciton to send Insteon broadcast messages. This type of message is used by the SimpleHomeNet range of devices and allows PowerHome to send the same type of message.
