ph_insteonwithret PowerHome formula function
Send a standard length Insteon command and waits for the return value.
The value returned will be the CMD2 value in the standard Insteon return
string.
ph_insteonwithret ( id, cmd1, cmd2 )
| id |
String. The ID of the Insteon device to send commands to. |
| cmd1 |
Integer. The command 1 value. Use standard 0
to 255 for Insteon Direct commands. Add
1000 to the cmd1 value to send Group Cleanup commands. |
| cmd2 |
Integer. The command 2 value. |
Integer. Returns the CMD2 value from the Insteon acknowledgement if successful
(a positive value). Returns - 100 if the ID cannot be found. -1 is returned
if the controller is not found, -2 is returned if the command fails due
to timeout, -3 is returned if the controller is not connected, -4 is returned
if the command fails due to NAK..
Use this funciton to send Insteon commands directly to a single device
and retrieve the answering response. This is useful for working with non-lighting
devices such as the EZIO8.
• ph_insteonwithret ("MID CHANDELIER",16,0)
• ph_insteonwithret ("OUT GDR EZIO2X4", 73, 0 )
• ph_insteonwithret("DWN-STAT",107,4)
