ph_insteonwithret1 PowerHome formula function
Send a standard
length Insteon command and waits for the
return value. The value returned will be the CMD2 value followed by the extended return
data if it
exists.
ph_insteonwithret1 ( id, cmd1, cmd2
| id |
String. The ID of the Insteon device to
send commands to. |
| cmd1 |
Integer. The command 1 value. Use
standard 0 to 255 for Insteon Direct commands. Add 1000 to the cmd1
value to send Group Cleanup commands. |
| cmd2 |
Integer. The command 2 value.
String. Returns the CMD2 value and extended
return data (if
it exists).
This function is nearly identical to the
ph_insteonwithret function except it is also capable of returning extended
data. Some Insteon standard commands return an extended data message so
this function will be able to return this data whereas the ph_insteonwithret
command ONLY returns the
CMD2 value.
ph_insteonwithret ("MID
CHANDELIER",3,2)
The above example sends a standard Device Text String
Request. This particular Insteon command will respond with an extended data
message which will be returned along with CMD2 as a
string.
