ph_ir PowerHome formula function
Sends an Infrared command.
ph_ir ( s, n )
s
A string identifying the equipment ID whose IR you wish to send.
n
An integer representing the key number of the IR you wish to send.
Integer. Returns a 1 if an error occurs while retrieving the IR data from the database. Otherwise a 0 is returned.
