ph_irdesc PowerHome formula function
Plays the Infrared code associated with the specified Equipment ID and Key Description.
ph_irdesc ( id, point )
id
The ID of the equipment whose IR you wish to play
point
The Key Description of the IR you wish to play. If the same Key Description exists for multiple buttons, then only 1 will be played.
Integer. Returns a 1 if an error occurs while retrieving the IR data from the database. Returns a 2 if the ID / KeyDesc cannot be found. Otherwise a 0 is returned.
