ph_iseven PowerHome formula function
Determines whether a whole number is even or not
ph_iseven ( num )
| Argument | Description |
| num |
Integer. A whole (positive or negative) number to check |
Integer. Returns 1 if the number is even. Returns 0 if the number is odd.
• ph_iseven(2) --> Return=1
• ph_iseven([TEMP2]-[TEMP3]) --> Return=0 if the result is an odd number
