ph_isodd PowerHome formula function
Determines whether a whole number is odd or not
ph_isodd ( num )
| num | Integer. A whole (positive or negative) number to check |
Integer. Returns 1 if the number is odd. Returns 0 if the number is even.
• ph_isodd(2) --> Return=0
• ph_isodd([TEMP2]-[TEMP3]) --> Return=1 if the result is an odd number
