ph_isssrunning PowerHome formula function
Returns whether or not a screensaver is currently running on the PowerHome machine
ph_isssrunning ( )
Argument Description
Integer. Returns 1 if a screensaver is currently active. Returns 0 if not.
Use this function to detect if the PowerHome machine is currently unattended or not.
ph_isssrunning()
