ph_iswslocked PowerHome formula function
Determines whether the PowerHome machine is currently locked or not.
ph_iswslocked ( )
Argument Description
Integer. Returns 1 if the PowerHome workstation machine is currently locked. Returns 0 if its not locked. Returns - 1 if there is error getting a handle to the desktop.
Use this function to determine if the PowerHome machine is locked or not.
ph_iswslocked()
