ph_jsontoyaml PowerHome formula function
Converts JSON data
to YAML
ph_jsontoyaml ( as_json )
| Argument | Description |
| as_json | String. A string containing properly formatted JSON data |
String. Returns the supplied JSON data
converted
to YAML data
Use this function to convert JSON data
to YAML (YAML Ain't Markup Language)...a text based markup language with
heirarchy represented by indentation (see
http://yaml.org). The conversion is done using a C#
YamlDotNet object
• ph_jsontoyaml('{"people":[{"name":"John","age":31,"city":"New
York","phones":["4075551212","3215551212","8885551212"]}]}')') - Returns the
following YAML string: "people:~r~n- name: John~r~n age: 31~r~n city: New York~r~n phones:~r~n - 4075551212~r~n - 3215551212~r~n - 8885551212~r~n"
