ph_killprocess PowerHome formula function
Kills the specified running Windows process.
ph_killprocess ( process )
process
Long. The process you wish to kill.
Long. Returns nonzero if the function succeeds and 0 if the function fails. Use ph_listprocesses or ph_locateprocess to determine the process you wish to kill.
Terminating a process can cause problems and should only be used if other methods fail.
