ph_latlongendbearing PowerHome formula function
Given
a starting latitude/longitude and an ending latitude/longitude, calculates the final
(end) bearing
in degrees
ph_latlongendbearing ( d_lat1, d_long1, d_lat2, d_long2 )
| Argument | Description |
| d_lat1 | Double. Starting latitude in decimal degrees |
| d_long1 | Double. Starting longitude in decimal degrees |
| d_lat2 | Double. Ending latitude in decimal degrees |
| d_long2 | Double. Ending longitude in decimal degrees |
Double. Returns the final (end)
bearing in decimal degrees going from the starting point to
the ending point
Use this function to calculate the final (end) bearing after traveling from a starting lat/long to an
ending lat/log
• ph_latlongendbearing(28.78,
-81.25,29.092410, -81.081711) - Returns an end bearing of
25.28137896027616
