ph_latlongstartbearing PowerHome formula function
Given a starting latitude/longitude and an
ending latitude/longitude, calculates the initial (start) bearing
in degrees
ph_latlongstartbearing ( d_lat1, d_long1, d_lat2, d_long2 )
| Argument | Description |
| d_lat1 | Double. Starting latitude in decimal degrees |
| d_long1 | Double. Starting longitude in decimal degrees |
| d_lat2 | Double. Ending latitude in decimal degrees |
| d_long2 | Double. Ending longitude in decimal degrees |
Double. Returns the initial (start) bearing
in decimal degrees going from the starting point to
the ending point
Use this function to calculate
the initial (start) bearing in order to travel from a starting
lat/long and arrive at an
ending lat/log
• ph_latlongstartbearing(28.78,
-81.25,29.092410, -81.081711) - Returns a start bearing
of 25.1999544221211
