ph_locatehandle PowerHome formula function
Locates and returns the handle of a process identifed by the specified parameters.
ph_locatehandle ( parentexe, parentclass, parenttitle, parentinstance, parentflags, childclass, childtitle, childinstance, childflags )
parentexe
String. A string representing the filename of the parent processes executable.
parentclass
String. The class of the process that is the parent of the process to be located.
parenttitle
String. The title of the window that is the parent of the process to be located.
parentinstance
Integer. The instance of the parent whose child process you're locating. The first instance is 0.
parentflags
Integer. Flags representing which of the previous parameters to use for locating the parent. Individual values should be added. 1 - Use parentexe, 2 - Use parentclass, 4 - Use parenttitle exact, 8 - Use parenttitle partial.
childclass
String. The class of the child process you're searching for.
childtitle
String. The title of the child process you're searching for.
childinstance
Integer. The instance of the child process you're searching for. The first instance is 0.
childflags
Integer. Flags that determine which of the child parameters to use. Individual values should be added. If the handle to locate is identified by the parent, use 0 to ignore the child parameters. 1 - Use child parameters, 2 - Use childclass, 4 - Use childtitle exact, 8 - Use childtitle partial.
Long. Returns the handle of the located process. Use the PowerHome "Object Spy" window for help in populating this function.
