ph_locateprocess PowerHome formula function
Locates the process value for the specified exe.
ph_locateprocess ( exe, instance )
exe
String. The exe filename or path and exe filename whose process you want.
instance
Integer. The instance of the exe to locate. The first instance is 0.
Long. Returns the process of the specified EXE. If the exe value contains a full path, then the search will be on the full path and filename, otherwise, the search will be just for the filename.
