ph_lockworkstation PowerHome formula function
This function will lock the PowerHome
workstation.
ph_lockworkstation (
Long. This function will return non-zero if
the lock operation has been successfully initiated (it does not return success
since the process executed asynchronously). 0 is returned if there is
an error.
Use this function lock the PowerHome workstation.
ph_lockworkstation()
