| Argument | Description |
| ai_type | Integer. A flags parameter that control how the luminance calculations are performed. See Usage below |
| al_color | Long. A standard RGB color value to determine the luminance of |
The ai_type parameter is a flags (values added together) parameter than determines how the calculation of luminance is performed. The proper value for ai_type is obtained by adding each desired value below together to achieve the desired calcuation result which would should end up as either 4, 8, 12, or 16:
To the above calculated value (either 4, 8, 12, or 16), add ONLY 1 of the below values to determine which set of weights to use
The weight values are below:
| Red | Green | Blue | |
| Weight 1 | 0.2126 | 0.7152 | 0.0722 |
| Weight 2 | 0.299 | 0.587 | 0.114 |
| Weight 3 | 0.241 | 0.691 | 0.068 |
Best default to determine perceived luminance/brightness would be a type with a value of 12. This converts gamma corrected RGB values to linear values, applies the first set of weights (most commonly accepted values) and then gamma corrects the result. This is also the best default to convert color values to grayscale.
Adding a value of 16 to the type approximates the conversion from gamma corrected RGB values to linear RGB values (raised to power of 2.0 vs power of 2.2). When using a type that includes 16, you would most likely NOT want to include a 4 or 8 in the type value. A type value of 12 or 16 should produce very similar results.
