ph_minutesafter PowerHome formula function
Returns the number of minutes that have elapsed between two datetimes.
ph_minutesafter ( dt, dt )
dt
A datetime representing the start datetime.
dt
A datetime representing the end datetime.
Double. Returns the number of minutes that have elapsed between the start and end datetimes. Partial minutes are represented in decimal format. If the end date is earlier than the start date, the returned value will be negative.
