ph_minutestostring PowerHome formula function
Use this function to convert a numeric
representation of minutes into a
string.
ph_minutestostring ( minutes, flags
| minutes |
Double. A decimal number representing the minutes to conver.
For one hour, three and a half minutes, the value would be 63.5 |
flags
Integer. This parameter controls how to
structure the output string. See
usage below.
String. The minutes converted into a string
representation
is returned.
Details of the flags parameter is in the
table below:
| 1 |
Add 1 to the flags parameter to include milliseconds in
the string output. |
| 2 |
Add 2 to the flags parameter to include seconds in the
string output. |
| 4 |
Add 4 to the flags parameter to include minutes in the
string output. |
| 8 |
Add 8 to the flags parameter to include hours in the
string output. |
| 16 |
Add 16 to the flags parameter to include days in the
string output. |
| 32 |
Add 32 to the flags parameter to include weeks in the
string output. |
| 64 |
Add 64 to the flags parameter to include months in the
string output. |
| 128 |
Add 128 to the flags parameter to include years in the
string output. |
256
Add 256 to the flags parameter to
include all other specified values in the output even if they
are blank.
Add individual values together to get the
flags value.
ph_minutestostring(63.5,14)
The above
example will take 63 and a half minutes and will convert it into hours, minutes,
and seconds (flags = 14). The returned output will be: 1 hour, 3 minutes, 30
seconds
