ph_mqttpub (MQTT Table syntax) PowerHome formula function
Publishes an MQTT message to a topic that is
currently defined and setup within the MQTT->MQTT Publish section of the
PowerHome Explorer. For syntax for a more general version of MQTT publishing,
please see this function:
ph_mqttpub
(General)
ph_mqttpub ( as_id, as_message, ai_type )
| Argument | Description |
| as_id | String. The ID of the MQTT Publish topic you wish to send a message to |
| as_message | String. The message you wish to publish |
| ai_type | Integer. Specifies how the message is to be
published. A value of 0 will send the message to the controller queue
where it is executed after other queued messages. Any other value causes
the controller to send the message immediately with feedback if
an error occurs |
Integer. Returns 0 if message was
queued successfully when ai_type = 0. Returns 0 if message was published
successfully when ai_type <> 0. Returns -100 if the
ID specified in as_in
is not found in the MQTTPUB table. Returns -1 if the
controller associated with the MQTT Publish topic specified by as_id is
not found. Returns -51 if the command is not supported by the controller.
Returns -11 if an error occurs during publish
when ai_type <> 0
Use this function to publish MQTT messages
to a previously defined MQTT topic in the MQTTPUB table. These definitions are
maintained within the PowerHome Explorer under the MQTT->MQTT Publish screen.
If you wish to publish a message to a topic not currently defined, then use the
other syntax for this function under
ph_mqttpub
(General) . For more information concerning MQTT, the protocol, and how
it is used, a very good reference can be found here:
https://www.hivemq.com/mqtt-essentials/
• ph_mqttpub("FAMRMLIGHT","On, 75%",0)
- Returns a 0 if the topic/message was successfully queued.
This
example will publish a message of "On, 75%" to the topic defined for
the "FAMRMLIGHT" ID in the MQTTPUB table. The QOS
and retain values will also be pulled from the "FAMRMLIGHT" table
entry
