ph_multixtime PowerHome formula function
Gets values from a previous incoming X10 time buffer.
ph_multixtime ( s, start )
s
A string identifying the buffer you wish to access. Use “” for the global buffer. Use "EXT" for the extended buffer. Use “A” for housecode A, etc.
start
An integer identifying the number of the command whose time you wish returned. 1 is the most recent and 20 is the oldest.
String. The time is returned as a string in the format of “hh:mm:ss”.
