ph_number PowerHome formula function
Use this function to convert a string
representation of a number into an actual
number.
ph_number ( value
value
String. The string you'd like to
convert into
a number.
Double. The string converted to
a number.
This function will convert a string
containing a number (including negative numbers and decimal numbers) into an
actual number that can be used where required within formulas. This function
primarily exists to handle the problems associated with the negative
sign "-".
ph_number("-56.25")
