ph_numtohex1 PowerHome formula function
Converts an unsigned integer to a hexadecimal string and specify the returned length.
ph_numtohex1 ( value, len )
value
Unsigned Integer. The integer whose value you wish returned in hex. Valid values are from 0 to 65535.
len
Integer. The number of hex digits that should be returned. Valid values are 1 thru 4.
String. Returns the number as a hexadecimal string of the specified length.
This function is essentially the same as the ph_numtohex() function coupled with the right() function.
