ph_pidclear PowerHome formula function
Allows the user to delete previously saved
PID data (created with the ph_pid( ) function) from the PID database table
ph_pidclear ( as_id )
| Argument | Description |
| as_id | String. The ID of the PID data you would like
to delete. Use an empty string "" to clear ALL the saved PID data |
Integer. Returns 0 if successful. If
an error occurs while deleting the data, a 1 will be returned. Specifying an
invalid PID ID will not return an error and will return 0. An error occurs only
if
the table delete fails
Use this function to delete no longer
needed PID data from the PID
database table
• ph_pidclear("TESTPID") - Returns 0
and deletes just the data associated with the PID ID
"TESTPID"
• ph_pidclear("") - Returns 0 and deletes ALL
currently stored PID
data
