ph_playsound PowerHome formula function
Plays a WAV file.
ph_playsound ( wav, flags )
wav
A string defining the path and wav file to be played.
flags
An unsignedinteger which represents how the wav file is to be played. Valid values which can be added (OR’ed) together are: 0 – Function returns after wav is played. 1 – Function returns immediately after wav starts playing. 2 – If file not found, play nothing. 4 – Play wav from memory instead of disk. 8 – Loop until function is called again with flags set to null. Should be combined with 1. 16 – If sound system is busy, don’t stop the currently playing sound and return without playing.
Integer. Returns a 0 if a wav capable device is present in the system, otherwise a 1 is returned.
