| Argument | Description |
| string1 | String. The string in which you want to find string2 |
| string2 | String. The string you want to find in string1 |
| start | Integer. A long indicating where the search will begin in string. Unlike the pos and posw functions, this parameter is not optional |
<html> |
This function is often used in conjunction with other string extraction functions to locate the "sweet spot" where an extraction should take place. For instance ...
ph_pos("[LOCAL1]","Humidity",1)
will find the location of the "H" in the word Humidity in the string, allowing, for instance,
a follow-on ph_regexsnap() to extract the data between the next <b> and </b> tags starting at that ph_pos() located starting position.
This function is also very useful in conjunction with the left() function to trim data off the end of a large string so that only the content of interest is being used to avoid "greedy" searches from finding unexpected data.
